Subject: Judy sitting pretty in her dynamic clothes!
Sue88 opened this issue on Sep 11, 2002 ยท 20 posts
Sue88 posted Wed, 11 September 2002 at 9:37 PM
I've been messing with this all afternoon and here are the results. This is how I did it: 1. Load Judy, then load a dress from the dynamic clothing library. 2. Go to the Cloth Room. Click on "New Simulation". For now, set the end frame at 10. I also enabled the cloth self-collision. 3. Select the dress from the figure list, then click on "Clothify", then Clothify again in the pop-up window. 4. Click on "Collide Against", then "Add/Remove" and select Figure1. 5. Click on "Calculate Simulation". 6. When it's done, go back to the Pose room and choose and load a sitting pose from the library. 7. Choose a prop for Judy to sit on. I just loaded the box primitive. 8. Turn the view sideways so you can see better. Open the animation window. You should be at frame 10. If not, go there. Size the box and put it under Judy where you want it. 9. Now go to frame 1 and put the box well behind Judy. (In the animation, it will be as if the box was sliding under her to sit on while Judy is getting in her sitting position. If you start out with the box being right under her, the dress will drape and stretch over the box.) 10. Go to the Cloth Room and Click on "Collide Against"/"Add/Remove", and select the box, leaving Figure 1 also selected. 11. Click on "Simulation Settings" and set the end frame at 30. 12. Calculate the simulation. When it's done, go back to the Pose room and everything should be fine. I hope it works well for everybody and I didn't leave out anything! Sue
