Subject: poser executable file
soc_inter opened this issue on Sep 12, 2002 ยท 14 posts
soc_inter posted Thu, 12 September 2002 at 12:38 PM
( Poser 5 )When I tried to register it, I got my challenge code and my response code and I printed it. When I click finish to close the window, a message error occur and said that Poser executable file has encontered a problem and needs to close. Well I can not open it since that. I got windows xp Did I do something wrong ?
c1rcle posted Thu, 12 September 2002 at 12:43 PM
have you tried reinstalling?, the challenge & serials will be the same
soc_inter posted Thu, 12 September 2002 at 12:49 PM
yes I tried it
c1rcle posted Thu, 12 September 2002 at 12:53 PM
the last time I had that sort of error it was a virus, but I don't think that's what this is, how about changing the compatability settings to windows 98, see if that changes anything
soc_inter posted Thu, 12 September 2002 at 12:56 PM
Before changing to windows 98, should I format my hard drive ?
c1rcle posted Thu, 12 September 2002 at 12:59 PM
NOOOOOOOOOOOOOOOOOOOOO! all you need to do is right click on the poser exe file, choose properties, then choose the compatability tab & change that to windows 98
soc_inter posted Thu, 12 September 2002 at 1:12 PM
I tried it and the answer was : Initialisation error unsupported driver call. Does it mean that I can only install poser 5 on drive C because I installed it on the drive E
c1rcle posted Thu, 12 September 2002 at 1:16 PM
that doesn't sound too healthy, try to install poser5 on the C drive if that doesn't work I'd fire off an email to the tech bods at Curious. you might need to repair XP, but try the install of poser first
elektra posted Thu, 12 September 2002 at 1:16 PM
I have Poser on my D drive and it registered just fine. Do you have a firewall app like Zone Alarm? Did you allow the Poser.exe through?
c1rcle posted Thu, 12 September 2002 at 1:19 PM
damn I didn't think of that, so used to firing up the wall & ignoring it I forget it's there
soc_inter posted Thu, 12 September 2002 at 1:42 PM
No I don't have a firewall. I will try to reinstall poser on the C drive. Thanks a lot
wdupre posted Thu, 12 September 2002 at 1:49 PM
XP has it's own built in firewall see if that is on.
soc_inter posted Thu, 12 September 2002 at 2:34 PM
Thanks a lot to every one who helped me. I reinstall poser 5 on the c drive and it works just fine. Thanks again
WiNC posted Fri, 13 September 2002 at 7:30 AM
You might want to make sure you haven't got NTFS compression on - if you do have that on in any other your drives it can cause issues with certain operation calls. I have had simular experience with certain games refusing to work on NTFS compressed drives... WiNC
