Subject: Poser 4 Transmaps to Poser 5
casamerica opened this issue on Sep 13, 2002 ยท 7 posts
casamerica posted Fri, 13 September 2002 at 1:40 AM
One thing I have learned is that those of us transporting favorite characters from P4 to P5 have some work cut out for them when it comes to transmaps. P5 has an extra transparency trait called Transparency_Edge. It does not appear to draw any traits or settings from your P4 character CR2s. Therefore it is set at 0. You will want to alter that. Otherwise your transparencies will appear rather translucent rather than transparent and you get all sorts of odd appearances. The image on the left is before adjusting the new Transparency_Edge trait, the one on the right after. I set the Transparency_Edge at the same setting as the Transparency. I know this sounds simple but it took me almost 4 hours to figure it out. The manual did not help much. So if this saves anyone a few hours great. BTW, the images were done with Firefly. Nothing fancy. I am just experimenting with various things so I am keeping my test subjects rather simple. casamerica
