Forum: Bryce
Subject: AAAAAAHHHHHHH!!!!!!! ....i need a little help :)
Anubis opened this issue on Mar 20, 2000 ยท 5 posts
Anubis posted Mon, 20 March 2000 at 8:44 PM
I've been trying and trying and trying and trying to make a *.OBP file for Bryce so all i have to do is click on my models and use them instead of always importing and grouping. I read in the manual that all i have to do is create my object, render, and export. But first off, it doesnt let me export anything. Second, i can't export as *.OBP only *.OBJ How do i make a "Bryce" object???
Ghostofmacbeth posted Mon, 20 March 2000 at 9:20 PM
Okay ... well there is a little triangle next to the create bar thinger. (I am tried so I will use words like thinger) Anyway you click on the little triangle and then you will get a whole selection of things like terrains and trees and such. You go to user items and as long as you have the item in question selected you should see it in the window. In user items you click on the add button and it will becoem it's own little item that you can use whenever you want .. that is the file you are talking about .. obd or whatever ..Good luck
Hawkfyr posted Mon, 20 March 2000 at 10:51 PM
Yes and you can imediatly export that, after you "add"it to your user library as an .obp, just cllick export from that dialog box also ctrl click succesive objects in the library to export entire groups of objects this is a good way to save your presets for storage. then delete them from the library to free up space. You can do this in any library, ...materials ...skies... good luck Hope this helps Hawkfyr
“The fact that no one understands you…Doesn’t make you an artist.”
Anubis posted Mon, 20 March 2000 at 11:08 PM
thanks to both of you. I recently posted a model in the bryce nad poser free stuff sections as .dxf files...now that i know how to make bryce files, ill have to update the link and repost :)
Hawkfyr posted Mon, 20 March 2000 at 11:11 PM
non-problematic :) Hawkfyr
