fcwilt opened this issue on Sep 14, 2002 ยท 4 posts
fcwilt posted Sat, 14 September 2002 at 5:14 PM
I have seen references to Victoria 1 and Victoria 2. Very briefly what is the difference? I have also noticed that 3rd party products often specify that they require one or the other. How do I determine which I have. Thanks much. Regards, Frederick C. Wilt
PheonixRising posted Sat, 14 September 2002 at 5:23 PM
Victoria 2 is an upgrade cr2 from the base Victoria 1 cr2. The difference is that the Victoria 2 cr2 contains many more morph targets for motion and shaping that were not part of the original Victoria 1 cr2. If your cr2 is named "Victoria" then it is 1.0If your cr2 is called "Victoria 2" then you have 2.0 All clothes and props for Victoria 2.0 work with 1.0 and vice versa. Though the morphs may be slightly different. 2.0 clothes may have morphs Victoria 1.0 doesn't have. It sounds like you have her already. I hope you got her at Daz. :) Anton anton@Daz3d.com
-Anton, creator of
ApolloMaximus: 32,000+ downloads
since 3-13-07
"Conviction without truth is denial; Denial in the
face of truth is concealment."
fcwilt posted Sat, 14 September 2002 at 8:23 PM
Thanks for the reply. I have two DAZ CDs, one with Michael, one with Victoria. On my computer the .CR2s are Victoria (2848K), Victoria Map (2849K), Victoria Map Morphs (8501K), Victoria Map2 Morphs (8501K). There are also Vicki (9114K), Vicki Map (9115K), and Vicki Map2 (9115K). Haven't a clue why there are so many. There are also some files in my download directory which have Victoria and Zygote in the name. I did buy some stuff on line in the past. Since there is no Victoria 2 I must have Victoria 1. Therefore the question now is: How do I get Victoria 2? Regards, Frederick C. Wilt
PheonixRising posted Sat, 14 September 2002 at 9:16 PM
www.daz3d.com you'll see a section called "Victoria"
-Anton, creator of
since 3-13-07
