Subject: Cloth Room Group Selection TIP!
TalmidBen opened this issue on Sep 15, 2002 ยท 5 posts
TalmidBen posted Sun, 15 September 2002 at 1:30 PM
Hey friends, I was trying to de-select some of the vertices, and for some reason, it was really hard! I was using the texture shaded mode. In Lightwave, if you use this mode, you cannot select vertices that are behind object faces. But if you go to wireframe mode, you can. I thought surely Poser 5 doesn't support this type of method, but LO AND BEHOLD IT WORKS!!! And when you use other preview methods, it also helps you acheive different goals, i.e. seeing the vertices better, selecting only front vertices, etc. This tip might be a no-brainer to some, but hey, it might help someone out. God bless, Ben
TalmidBen posted Sun, 15 September 2002 at 1:31 PM
Here is the wireframe mode, that allows selecting/de-selecting vertices that are on backfaces . . .
PheonixRising posted Sun, 15 September 2002 at 2:34 PM
Cool. Yeah it can drive you crazy. The grouping tool is not really designed for selecting complex groups of polygons or hi-res objects. If you are ever at a point where you are ready to scream you should consider using UVmapper. It can save your sanity.
-Anton, creator of ApolloMaximus: 32,000+ downloads since 3-13-07
"Conviction without truth is denial; Denial in the face of truth is concealment."
NEW The Poser FaceInterMixer
TalmidBen posted Sun, 15 September 2002 at 2:57 PM
Yep, I almost lost there there Anton! But I'm SO GLAd the preview mode affects the grouper, or I would have hated the tool's lack of user friendliness, but it's all good!
bloodsong posted Sun, 15 September 2002 at 5:44 PM
heyas; the grouper was always supposed to do that, but it was... flaky. in p5, the grouper is MUCH more well-behaved.
