Subject: I hope you know how to import face 3D obj into face room
-Waldo- opened this issue on Sep 21, 2002 ยท 3 posts
-Waldo- posted Sat, 21 September 2002 at 1:12 AM
I could not find a way to import penny's face into the face room. If you know how please post it here. Waldoo
triceratops2001 posted Sat, 21 September 2002 at 1:56 AM
Face room is not use to import obj. If you want to use the obj as a morph target, import in the pose room.
-Waldo- posted Sat, 21 September 2002 at 11:28 AM
When I loaded one of my map, it asked to specify which figure type map belongs to. It also offered options to select P5 male or female. But this option was not offered when you import photos in front and side box. The original 3D face default in face room is for p5 male only. For instance, I imported photos of a female face in front and side box and then I fixed it to work with 3D face (male head because no option provided to select female) I exported it into texture map. That texture map will only work on male head not female head. I tried to load the texture map in face room and it asked me to specify figure so I selected female that is what happened at #2 female head with disorted map. Female 3D head only will provide in face room if you load the texture map. Curious labs is supposed to put it in menu where we can select male or female head to work on. It would be nice if they add 3d head and body import option in. Waldoo
