Dark_Raven opened this issue on Sep 21, 2002 ยท 4 posts
Dark_Raven posted Sat, 21 September 2002 at 2:42 AM
I have been using PSP7 and decided to give Photshop a try im using a trail version to test it out and well there are a few tools I cant seem to find that PSP& have that I love, the drop shadow tool and the flood fill tool dose PhotoShop have these if so where can I find them mine seem to be missing them? Dark Raven
Mongo posted Sat, 21 September 2002 at 5:07 AM
Either on your layers pallette or under layers menu, there is "layer style". there you can find the drop shadow. As far as "flood " goes, there is a "fill" under edit. Not sure if that is what you want. What does "flood" do?
M
Slynky posted Sat, 21 September 2002 at 8:44 AM
the normal fill tool and the gradient fill tool take the same space. to find the normal fill, press and hold the left button/mac mouse button on the gradient tool and the fill tool will pop up to be selected. this woprks on any tool where you see a little icon in the lower right hand corner.
retrocity posted Mon, 23 September 2002 at 11:24 AM
Keep in mind, the "drop shadow" is a Layer Style that will impact whatever is on that layer (text, partial image...). If there aren't any transparent areas on the layer you may not see any effect. (It is adding the drop shadow to the whole image which is outside of your viewing area)
I'm not sure but doesn't FLOOD in PSP also deal with a "pattern" as well as just colour or gradient?
If this is the case you will also want to look at the "Define Pattern" under the Edit menu. This allows you to select an area of your image and make a pattern out of it, which can be selected as a fill.
retrocity
