Subject: MeTaL Fixer and Poser 5 - FYI
jelisa opened this issue on Sep 25, 2002 ยท 4 posts
jelisa posted Wed, 25 September 2002 at 12:39 PM
FYI for Poser 5 users: It seems that there is a slight enough difference in the P5 pz3 files that MeTaL Fixer has a problem with them. We are working on this, but it will be about a week before HT can do so. Unfortunately, I only discovered this last night. In the meantime, you can fix the problem in one of two ways: 1. After saving the pz3 file in P5, open it in P4 (OK on the previous version message) and resave it using a new filename. Now, run MeTaL Fixer on the mtl file using the renamed pz3 P4 file. OR 2 After you run the mtl fix (using the P5 pz3 file), open the mtl file in WordPad and look at the first pathname. It will look something like this, depending on your directory structure: map_Kd DPoser 4runtimetexturesDAZCharactersMilWomV2HeadM.jpg map_Bump DPoser 4runtimetexturesDAZCharactersMilWomV2HeadBump.jpg To fix, simply do a find/replace to delete the pathnames in front of 'runtime', for example, I would replace 'DPoser 4' with nothing. Save the mtl file and import the obj into Bryce. We apologize for any inconvenience this may cause, but it will be fixed as soon as possible. -darlisa
thgeisel posted Wed, 25 September 2002 at 2:58 PM
No inconvenience! Your program is great! Thanks for your work!
x2000 posted Wed, 25 September 2002 at 6:47 PM
Thanks for the info. I hadn't tried it with P5 yet, so you've saved my computer from a whole lot of cursing out.;)
Dale B posted Wed, 25 September 2002 at 9:34 PM
Thanks, Jelisa!
