Subject: PLEASE HELP
raz opened this issue on Sep 27, 2002 ยท 6 posts
raz posted Fri, 27 September 2002 at 12:31 AM
im trying to "mount" a camera in a drivers seat of a CR2 car. I paented it and wanting to make 1st person view of a driving seqyece for a project. i got the AUX cam to lock in the seat, but when i move the car back a bit, the camera starts to fall behind on the axis until it's out of the car all together...how do i lock it in so it stays, and I can film from it with out it moving?
VirtualSite posted Fri, 27 September 2002 at 12:38 AM
After parenting, did you try locking the camera?
Nosfiratu posted Fri, 27 September 2002 at 1:49 AM
Are oyu trying to edit a CR2 or do this inside Poser? I've tried it inside P4 and P5 (position cam, select it, then select OBJECT>CHANGE PARENT). One thing, I noticed that the camera seems to move after I parent it. But if I move it back then move the child, the cam retains its position relative to the child. Anthony Hernandez Curious Labs
Marque posted Fri, 27 September 2002 at 9:44 AM
What a great idea! Marque
lesbentley posted Fri, 27 September 2002 at 11:43 AM
Raz, set the focal length how you want it, then set the scale of the camera to 100%, then parent it to your object. This will fix the problem.
Fore some reason a Poser4 (I don't know about P5) camera won't track its parent properly if the camera scale isn't 100%. You also get this bug if you parent an object to the camera, tracking won't be correct unless the scale of the camera is 100%.
Also note that when you change the focal length of a camera Poser automatically changes the scale of the camera.
raz posted Sat, 28 September 2002 at 5:56 AM
aahhh! that wasit!! thanks! :)
