Forum: Vue
Subject: OCTOBER CHALLENGE BEGINS
gebe opened this issue on Sep 27, 2002 ยท 16 posts
gebe posted Fri, 27 September 2002 at 5:37 AM
"Deep forest" HERE IS THE THEME CHOSEN BY CERMIT "DEEP FOREST" Create a forest scene. It's a challenge to use various vegetation. What is your vision of a forest in the morning? Or maybe in the evening? You decide. Will it be dark and gloomy or clear and bright? Will there be sunlight shining through the branches or maybe moonlight instead? It's up to you." GOOD LUCK ;-) AND HERE ARE THE RULES: - You only can submit one image. Thats why you should take your time to work on it. - All submitted images will be uploaded by me with just a number by side the image, without the name of the artist. Also the artist will stay anonymous until the votes are closed. I will then change all the numbers for the names of the creator of the image:-). This means that you cannot show your image somewhere else until the votes are closed, otherwise it cannot be accepted. I choose to do so to give an equal chance to all of you. - You have to send your submission to me by e-mail to: gebe@renderosity.com Your image must be 800x600 or smaller and not more then 190 kb big. Bigger images are not accepted. Please send also a thumbnail not bigger then 180 wide and 135 heigh, 15 KB maximum. Your images must be in JPG format. Challenge starts today, September 27 and will be closed on October 27, 3:00 a.m. NY time (9:00 a.m. Paris time). The reason for this is, that our second Vue contest will close just after and I need the time to manage all together beside my usual work. Good luck to all and have fun. Guitta
