Laverboy opened this issue on Sep 27, 2002 ยท 4 posts
Laverboy posted Fri, 27 September 2002 at 4:27 PM
I have PSP 7....when I render my images i cant remove the background even if i do change the colour to light green. This is especially a problem with the hair. I even tried colour replacer. What do you do?
bushi posted Fri, 27 September 2002 at 11:08 PM
You might try rendering over black and saving as a .tif file. Doing that will include the alpha channel with the render. You can then make the black background transparent in most paint programs.
EnglishBob posted Mon, 30 September 2002 at 7:10 AM
Yep... save as TIF or PSD. In Paint Shop, select "import mask from alpha channel". Your figures will then be isolated, with the background transparent; then you can add other layers behind them. There's no need to do anything special to the Poser background with this method.
Laverboy posted Mon, 30 September 2002 at 9:37 AM
thanks =)
