bloodsong opened this issue on Sep 29, 2002 ยท 24 posts
bloodsong posted Sun, 29 September 2002 at 8:02 AM
heyas, anton! first, is this the correct name for poses that apply custom materials to body parts to do the quickie bodysuit type of deals? if not, what's the correct name? second, can you give a run-down of how they work? now i know you change the custommaterial 32 (or whatever it is) to any other number, and then insert the material settings into the body part, there. what i'm not sure about are the other rules. i was looking at the mcfs mat-div file for michael, and i saw after the custommaterial, it said 'material skinbody' and then had the definitions. do you make one material entry for each material on the body part you want to change? do you need a custommaterial entry for each material? like for example, if i wanted to make the headskin, lips, and eyebrows on the head all one custom material, how would that look? thanks!
