Zhann opened this issue on Oct 01, 2002 ยท 30 posts
Zhann posted Tue, 01 October 2002 at 1:45 AM
Hi All, I just sketched out some landscapes with snow (yes, I still sketch on paper first), snow on trees, snow on rocks, snow on grasses, snow on everything, and now that I think about it ice too...any tutorials or suggestions on the how's and where's of snow? Any thing is appreciated (I'm just getting the hang of Bryce, these will be my 'first' landscapes) Thanks afore hand...Zhann
Bryce Forum Coordinator....
madmax_br5 posted Tue, 01 October 2002 at 3:19 AM
Check brycetech.com fire and ice tutorial
Zhann posted Tue, 01 October 2002 at 3:27 AM
Thanks, will do...:)
bikermouse posted Tue, 01 October 2002 at 3:57 AM
Zhann, It seems that you can achieve icey terrains by checking light instead of normal rendeer,use light colored procedural textures and increasing bump height in the material editor, but I'm too impatient to test it our. it turned what was a 5 minute quick test render into an 11 hour test render. I aborted before it got through - wish I'd have saved a pict of it now. Just a thought: offsetting a copy of your tree etc., making it a whitish texture and inreasing bump height and combining them as a boolean might work. BTW your gallery images look very good. - TJ
airflamesred posted Tue, 01 October 2002 at 3:59 AM
yes I heard a similar one Duplicate everything in the scene, group and nudge up slightly - add snow tex
Zhann posted Tue, 01 October 2002 at 4:39 AM
Thanks TJ for lookin' at my work :), and I'll give the duplication thing a try, BTW, I live in Colorado so snow is here already, and there are great mountains to use as models, kinda got me into thinking snowscene... Zhann
Zhann posted Tue, 01 October 2002 at 4:42 AM
Can trees be boolean objects? (as you may notice, haven't gotten to that in the manual yet :)...)
bikermouse posted Tue, 01 October 2002 at 4:48 AM
If the tree is all one group you can boolean that group with another group or object. In B5 I don't know. Trees were one of the things they updated for B5. - TJ
madmax_br5 posted Tue, 01 October 2002 at 4:51 AM
No, trees in bryce5 have no boolean abilities.
Zhann posted Tue, 01 October 2002 at 4:54 AM
Yup, I have B5 alright, had to ask here just to find the file menu bar, they failed to mention how to access it in the paperwork, :p...
Zhann posted Tue, 01 October 2002 at 4:55 AM
Darn!
Zhann posted Tue, 01 October 2002 at 4:57 AM
Could I just group two trees (different textures), one slightly offset from the other to get the effect?...
bikermouse posted Tue, 01 October 2002 at 5:10 AM
Zhann, Well it's all an experiment at this point. might as well try it. Can trees in B5 be disassembled in any way? You might be able to work with that if so. If worst comes to worst you could import a tree created in another app unless this is for the all bryce challenge. I think Virtual Tree has a few neat trees in Renderosity's freestuff you could use to try with the ideas presented about booleans. - TJ
Zhann posted Tue, 01 October 2002 at 5:20 AM
Not for anything special, I do landscapes in acrylic and I wanted to do some digitally, see what can be done in B5...I've done some in Terragen, but I can't get what I'm after...soooo, onward and upward, I'll see what happens, I'll see if I can take 'em apart and reassemble...what could happen after all?...
madmax_br5 posted Tue, 01 October 2002 at 5:30 AM
You can apply a completely transparent material to the trunk of a tree, then apply ice to the leves and offest it just a little bit.
Zhann posted Tue, 01 October 2002 at 5:43 AM
Done! Look for a strange image in the next few days or thereabouts, possibly, maybe, just don't laugh...
bikermouse posted Tue, 01 October 2002 at 5:52 AM
Zhann, If it is half as good as your gallery images, I don't think anyone will be laughing - they will be too busy picking their jaws off the floor. - TJ
Zhann posted Tue, 01 October 2002 at 5:57 AM
I can only hope to be as good as you guys someday, I've seen some really amazing stuff...
bikermouse posted Tue, 01 October 2002 at 6:14 AM
Zhann,
I have a looong way to go before I can be considered one of the "you guys". I'm working on it though.
Speaking of which could you check out the star field in
this render for me and tell me what you think of the starfield itself? it's actually a textured dome and I was wondering if it looks even a little bit like a sky full of stars? I mean it looks ok to me but I sometimes fail to be objective about my own stuff.
Flak posted Tue, 01 October 2002 at 6:33 AM
Looking forward to your pic, Zahnn. I tried a snow pic ages ago, and gave up on the trees in frustration.
Dreams are just nightmares on prozac...
Digital
WasteLanD
miden1138 posted Tue, 01 October 2002 at 6:59 PM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=81916&Start=73&Artist=miden1138&ByArtist=Yes
I tried a snow scene once in B5, and I figured out a real easy way to put snow on your trees.First, take all the leaves off of the tree by reducing the number of leaves in the tree lab to zero. Then instead of using a trunk material for the tree, use a snowy texture from the "Plains and Terrains" group. If I remember correctly, there are a couple that have a rock texture that look a lot like bark. You may have to play with the colors in the DTE and change the texture from "World Space" to "Object Space" for it to work, tho'.
Hold on, let me see if I can find the image...Ah, found it.
If you look closely, you can see the snow on the tops of the branches. If I remember correctly, that's how I did it.
Hope this helps!
Mike
Zhann posted Wed, 02 October 2002 at 1:06 AM
Mike, great pic, I love the distant mountains, and the tree limbs do look like they have snow on 'em. I was thinking more of coniferous type trees, but now I think I might try a few deciduous also... thanks for the looksee... Zhann
madmax_br5 posted Wed, 02 October 2002 at 4:07 AM
BTW Zhann, you can make a transparency layer in the material itself.
madmax_br5 posted Wed, 02 October 2002 at 4:12 AM
madmax_br5 posted Wed, 02 October 2002 at 4:30 AM
Zhann posted Wed, 02 October 2002 at 5:54 AM
madmax_br5 posted Wed, 02 October 2002 at 9:19 AM
For that much snow, you might try rendering the tree with a distance mask, then open i in photoshop and stagger is a bit. Then back into bryce import as a lattice, clip, and stick it over the real tree. I will have to try this.
Aldaron posted Wed, 02 October 2002 at 12:49 PM
madmax_br5 posted Wed, 02 October 2002 at 10:28 PM
Zhann posted Wed, 02 October 2002 at 10:42 PM
Hey, I like both of those, will try both ways...Oh,BTW anybody need reference photos of stuff just ask, photography is my second artform...
