scorpion3367 opened this issue on Oct 02, 2002 ยท 2 posts
scorpion3367 posted Wed, 02 October 2002 at 4:57 PM
Hi,
I'm hoping someone might be able to point me in the right direction for exporting a wireframe animation. I know you can set the Document Display for wireframe but how would you set the render/animation settings to export a movie in this format? Is it possible? When I've tried to render, even with no maps assigned to anything, I still get a surface covering the model which I don't want for this particular animation. I've looked high and low through all the settings I could think of with no luck. If there is a way, I wasn't successful in finding it so if anyone has the answer, I'd sure appreciate it.
Thanks for your time and effort.
VIDandCGI posted Wed, 02 October 2002 at 6:31 PM
K there are a couple of ways to do this 1) goto Animation>Make Movie> then set quality to current display settings, though this may have some undesired effects. The second way s a bit harder and requires more time but has better results, you take the UVmaps of every model and turn them B&W and invert there colour so tht you have a white mesh on a black Background, then apply each map to its correct part as a transparency map, when rendered the figures will come out as wireframes if applied properly in this case make sure quality is set to render settings :) hope this helps
