Subject: 1,000,000 SQUARES in Poser4 !!! ..........................................
geep opened this issue on Oct 02, 2002 ยท 13 posts
geep posted Wed, 02 October 2002 at 11:14 PM
I HAD to try it, ... ..................... and IT WORKED !!! cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
EricofSD posted Wed, 02 October 2002 at 11:40 PM
Well, Sheriff Joe will be glad to fill all those little cells. Thanks.
Crescent posted Wed, 02 October 2002 at 11:58 PM
Yeah, but where's the green baloney? (I did find the pink underwear, though.)
EricofSD posted Thu, 03 October 2002 at 2:23 AM
So you know the good ol boy, eh? I told one of my criminal clients about the pink underware today. I think he wants to run me over with a bus now.
quixote posted Thu, 03 October 2002 at 9:29 AM
I'll take PNU to block, please Alex.
Un coup de dés jamais n'abolira le hazard
S Mallarmé
hauksdottir posted Thu, 03 October 2002 at 9:43 AM
999,999 squares on the wall, 999,999 squares... if one of the squares should happen to fall 999,998 squares on the wall Hmm... not very musical. Needs something. I know! Dr Geep, can you maintain an ambient temperature in the mid 50s? That wall would make a dandy wine cellar. ;^) Carolly
Routledge posted Thu, 03 October 2002 at 10:05 AM
A millions okay, but a million and one, now that`s special!
shadownet posted Thu, 03 October 2002 at 4:51 PM
Okay, good Dr. now explain to me (insert dummy) what this means?
lesbentley posted Thu, 03 October 2002 at 6:32 PM
Interesting, but I think the terminology is not the best. It seems commonly accepted, and logical that one Poser unit = 1.000 on a translation dial, (which by some conventions = 8"). It seems that 1,000 of your PNU = 1 Poser unit, there seems to be a potential here for confusion between a PNU and a Poser Unit.
geep posted Thu, 03 October 2002 at 9:45 PM
Senior lesbentley is ABSOLUTELY CORRECT !!!
Dr Geep has made another boo-boo !
[but NOT on purpose - I assure you]
I have arbitrarily defined a PNU as the smallest increment that you can change something in the Poser "studio."
That is, changing "yTran" from 0.000 to 0.001 would be an increment of one PNU.
I believe Mr. lesbentley meant that 1.000 on the Poser dial should be 8' (feet) and NOT 8" (inches).
I have found that using 1.000 to equal 8.333... (repeating decimal) feet works very well because that makes 1.000 equal to 8 and 1/3 feet or 8' 4" or 100" EXACTLY !!!
Thus:
1.000 = 100"
0.100 = 10"
0.010 = 1"
0.001 = 0.1"
This is the scale that my 9' Prop Scale is based upon.
So, I guess I only have 1 square Poser Unit and not 1,000,000.
sniff
BUT ...
I DO still have 1,000,000 squares !
Oh well, it was fun, anyway.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep posted Thu, 03 October 2002 at 9:48 PM
Maybe I should have called it a "PU"
Now I am SURE someone can make something out of THAT!
(Poser Unit) instead of a "PNU" (Poser Native Unit).
dg ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
Nance posted Thu, 03 October 2002 at 10:07 PM
re:"the smallest increment that you can change something in the Poser " uh, while the dials only display three decimal places, they do accept smaller values, i.e., ten-thousandths of a "PeeYewh" (.0001).
geep posted Thu, 03 October 2002 at 10:23 PM
I wasn't going to mention THAT because it will REALLY "muddy the water" for anyone who is gonna ask,
"Ok, I only can see 3 decimal places on the display, where is the ..., etc."
Wouldn't you agree?
OR - are you are referring to P5?
I would refer you to the original "Subject" of this thread.
Besides, do we really need to measure down to one ten-thousanth of an inch?
1/10 of an inch (using my scale) is the distance that Poser's GROUND is below 0,0,0 (the yTran value).
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
