Forum: Vue
Subject: Poser Hair into Vue4
MeInOhio opened this issue on Oct 04, 2002 ยท 10 posts
MeInOhio posted Fri, 04 October 2002 at 7:26 PM
I posed mike with the morphing flat top in Poser 5 and then exported him as an object file so that I could import him into Vue 4, but I'm having problems with the hair. (I tried bring a Poser 5 pz3 file into Vue, but it didn't work. Then I tried opening the P5 figure in P4 so that I could resave it, but it asked me to locate every texture and after I did, I ended up with an empty scene because I assume it couldn't find the obj files. I believe this happens because I created my own runtime folder for my purchased models.) So I'm trying to do it the old fashioned way. I found that tutorial Mike into Vue and I followed it. Things worked well for the eyes, brows and lashes. But the hair is something else. I followed the same procedure, as for the brows and lashes but it just isn't working. If you look at the transmap, it looks like it's not lining up correctly with the color map. Parts of the color map are cut away and parts that are white are remaining. What am I missing. I tried inverting. I tried rotating. I didn't try flipping it, because I couldn't find a way to flip the map. It looks fine in Poser. I checked in Poser to make sure I'm using the right maps, and I am. So what have I missed? Thanks. Kevin
