Staby opened this issue on Oct 05, 2002 ยท 18 posts
Staby posted Sat, 05 October 2002 at 3:44 PM
Staby posted Sat, 05 October 2002 at 3:47 PM
Nosfiratu posted Sat, 05 October 2002 at 3:48 PM
And your material settings on the plane?
Staby posted Sat, 05 October 2002 at 4:47 PM
Staby posted Sat, 05 October 2002 at 4:49 PM
Nosfiratu posted Sat, 05 October 2002 at 4:50 PM
Remove the REFLECT_2 node. You don't need it. THis combined with your purple diffuse color is probably the reason for the lines. Make your diffuse color white and delete that second reflection node.
iancollins posted Sat, 05 October 2002 at 5:11 PM
Staby,
It looks like you used the simple square prop for the mirror. Instead, use the Square Hi-res prop. You should find the artifacts disappear.
Ian
Staby posted Sat, 05 October 2002 at 5:53 PM
Thank you iancollins the Hi-res square don't show artifacts. It is a relief. Everything was working fine with Poser 5 so far and I was worried. Now I only need to find out some good settings to make a mirror...
iancollins posted Sat, 05 October 2002 at 6:18 PM
Here's the simple square-prop mirror with no artifacts.....
iancollins posted Sat, 05 October 2002 at 6:21 PM
Make sure that you set both the diffuse and specular colours to black (RGB=000).
Haven't finished testing to see if there are any limitations with this setup but, so far, I haven't found any.
Ian
Nosfiratu posted Sat, 05 October 2002 at 6:24 PM
black not white. can you tell I've been awake far too many hours? ;-) A
Little_Dragon posted Sat, 05 October 2002 at 6:38 PM
Alternatively, instead of setting the colours to black, you can set Diffuse_Value and Specular_Value to 0.
iancollins posted Sat, 05 October 2002 at 6:42 PM
Anthony,
I'm finding that, if I make the diffuse and specular black, plugging the reflect node into the reflection colour channel still gives artifacts with the simple square-prop mirror.
But, if I plug the reflect node into the Alternate Diffuse channel (as in the example I gave above) then everything seems to work ok. I can't understand why that should be......or......am I missing something..?
Ian
Nosfiratu posted Sat, 05 October 2002 at 6:59 PM
Well, the DIFFUSE channel is a lighting model. This is the same as taking a LIGHTING>DIFFUSE node and plugging it into ALT-DIFFUSE. So I can see where that would affect the renders, but I'm not 100% sure of what's going on behind the scenes.
praxis22 posted Sat, 05 October 2002 at 8:39 PM
I wouldn't worry about it Anthony, I don't think anyone else is either :P
Roy G posted Sun, 06 October 2002 at 12:02 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=871249
Artifacts look similar to the ones I'm seeing in the thread at the attached link. Are you using the two sided plain? Try using the exact same settings with the one sidded plain.Staby posted Sun, 06 October 2002 at 5:19 AM
Roy G posted Sun, 06 October 2002 at 12:01 PM
The object actually looks rougher in the reflection. That's odd.
