Karma opened this issue on Oct 05, 2002 ยท 3 posts
Karma posted Sat, 05 October 2002 at 7:47 PM
I installed the patch, now I can't access my parameter dials. I've also tried to hit control-I and select it from the pull down menu and it will not appear on my screen. I have also tried to uninstall it and just use poser 5 without the patch and still have the same problem now.
Tirjasdyn posted Sat, 05 October 2002 at 8:29 PM
What is your monitor resolution? Did you get the new version of the patch? The uninstall might not help if the registry settings were not removed.
gryffnn posted Sat, 05 October 2002 at 8:51 PM
Didn't someone have a problem with it being off screen? You can try to old Poser 4 trick - select Edit, Preferences and then reset to factory settings, and see if it shows up.
