Forum: Poser Technical
Subject: Conforming to a Horse
Darkworld opened this issue on Oct 07, 2002 ยท 9 posts
Darkworld posted Mon, 07 October 2002 at 7:11 AM
wondering how this might be done? I made the conformer, it fits perfectly, but when i use the prog i have to match it to the horse's obj and actually make a conforming cr2, it fails. anyone know how i might make the cr2 for the harness conforming correctly? thanks! Brian
Darkworld posted Mon, 07 October 2002 at 3:09 PM
well as you can see i got the conformer lined up perfectly, i used p-wizard to make the obj conform to the horse itself, and the new cr2 imports correctly, perfectly in place (top picture) but then when i click Conform To, it looks horrible (bottom picture) any ideas? thanks! Brian
Darkworld posted Mon, 07 October 2002 at 4:14 PM
figured it out, the horse character by default (even when you zero the figure) has the hips offset by 0.4 on the Y scale, once i found this it was easy to fix.
bloodsong posted Mon, 07 October 2002 at 5:26 PM
Attached Link: http://www.3dmenagerie.com/
heyas; yup, good job. check the 'painlessly easy conforming clothing' tutorial for specs on creating conformers for any figure. (in with the goodies.)
STORMCLOUD posted Thu, 24 October 2002 at 9:15 PM
the horse character by default (even when you zero the figure) has the hips offset by 0.4 on the Y scale, Riddle me this one. if you would. How did you know are for that matter find out just how far it was off If it was set to zero(0) out ? i think i could use that info. in other ways. No matter where you go there you are
Darkworld posted Fri, 25 October 2002 at 10:36 AM
right, the horse is offset by .4 on the Y scale AFTER you zero the figure, you click the hips and there it is, it says Y position is -.004 or whatever it said exactly... so all i did is put the OPPOSITE of that into the "figure offset" when i imported the conformer and then poof, it appeared exactly perfectly on the horse. Then after i did the hierarchy and saved the figure to the library, i just used poser wizard to make the cr2 conforming, and then it worked fine.
bloodsong posted Fri, 25 October 2002 at 4:45 PM
er... but you're supposed to make the conformer's hip y trans 0, not negative of the conformee's. or that offset weird stuff. to really REALLY zero a figure, you follow this procedure: 1: open the jp window and hit the 'zero figure' button. 2: grab the hip and set the x/y/z trans dials all to 0. 3: grab the BODY and set the x/y/z trans dials all to 0.
Darkworld posted Fri, 25 October 2002 at 5:10 PM
well your right exactly hehe, but in my case the conformer was already made using the horse in the wrong place, so when i hit conform it was off... so thats how i fixed it; if you zero the figure COMPLETELY before you ever start modeling anything you should be ok hehe.
STORMCLOUD posted Sat, 26 October 2002 at 6:35 AM
THANKS it those lil details that make life fun. eh ? (smirk) one other thing. i recently founda nice lil prog. since i have to wait on the PBOOST i believe it is. it was a freebie somewhere ,i used it and it put things were they belonged. instead allowing Pboost to just work as the middle agent . but for some reason its gone poof ! .. i used it once it worked excellent. .. any ideas what it was and where ? im still checking my History and harddrive manaually, till then thanks again
