Subject: Hi need help to get free stuff post working again.
Velen opened this issue on Oct 08, 2002 ยท 3 posts
Velen posted Tue, 08 October 2002 at 11:44 AM
Attached Link: http://64.171.55.164/greendress.jpg
hi ok how do i set up apachie web server on win 2k to let the ojb files ill be releasing be uploaded ? anyone know ? here is one of the dresses in the cloth room ill be posting when i get this to work. laters Vel
Penguinisto posted Tue, 08 October 2002 at 12:28 PM
Attached Link: http://www.apache.org
Err, good luck. Two things spring to mind here: 1) If it's a popular download, I hope you've got the bandwidth to spare. I host stuff here with permission from the school, since we have the wires and the data/traffic generated are a benefit to my students. If you're doing this from say, a home Cable or DSL line, be prepared to not use the Internet for anything when you get home... the line will be all bogged down. If you're doing this from work, make sure you have permission first, otherwise you may wind up unemployed, or worse, they may stick you with the bill for all that bandwidth. 2) While I commend you for choosing Apache, do know that Windows isn't exactly the best OS for serving web pages. An obscene chunk of the server's resources will go towards feeding the server's largely unused GUI, and even with Apache instead of IIS, Windows is a ripe and easy target, especially as a box facing the internet on a 24/7 basis. Otherwise, just drop the zip file in .../htdocs/ (the same place you dropped the .jpg in your link), and you're all set. HTH a little, /P
Velen posted Tue, 08 October 2002 at 7:48 PM
thanks for the info well i normal just use the web server to host pics i post for the boards here. and yes i would be useing my dsl line :/ so hadnt thought of the posable load and sence there are so few things out there for p5 now it will proly be hit hard. so guess i need to look for a diferent host method. thanks for the input. Laters Vel
