T:-)M opened this issue on Oct 09, 2002 ยท 5 posts
T:-)M posted Wed, 09 October 2002 at 5:22 PM
I tried to create a new face using the face room - but it didn't work.... The points are anywhere but not on the right places in the face. I tried to pull these points to the right places but the result was not better...
Do You have some hints for me - I read the whole part about the face room in the poser 5 manual... but didn't find any help......
Thank You so much..
T:-)M
Tirjasdyn posted Wed, 09 October 2002 at 5:28 PM
Hrm, some one posted that you had to move the lines to the right place before moving the dots. I don't know if this makes sense I haven't tried making a face yet.
Spanki posted Wed, 09 October 2002 at 6:29 PM
I had the same problems when I first started playing with it... here's THE best advise you'll hear to get you started: DO NOT start moving the green dots around right away. See those little buttons to the left of the front/side view images? Use those to scale, poistion and orient the outline first. Doing this will leave the green dots (and the red lines) in basically the right shape/position... if you just start dragging the green dots around first, you'll likely get them way out of whack. Once you have the outline pretty close, you can fine-tune using the green dots. I screwed around with the green dots for over an hour and ended up with a mess... then I found those buttons on the left and had a pretty decent mapping in about 2 minutes.
Cinema4D Plugins (Home of Riptide, Riptide Pro, Undertow, Morph Mill, KyamaSlide and I/Ogre plugins) Poser products Freelance Modelling, Poser Rigging, UV-mapping work for hire.
quixote posted Wed, 09 October 2002 at 6:58 PM
I also find that if the dimentions of both faces (front and side views) are close to being the same, you seem to get better results.
Un coup de dés jamais n'abolira le
hazard
S Mallarmé
T:-)M posted Fri, 11 October 2002 at 5:54 PM
Hi, thank You for posting... ... hmmm I tried this... but it is nut much better now... T:-)M
