Subject: I've made an animation :o)
TrekkieGrrrl opened this issue on Oct 13, 2002 ยท 8 posts
TrekkieGrrrl posted Sun, 13 October 2002 at 2:59 PM
Attached Link: http://medlem.spray.se/cutiecats/graphic/Movies.htm
Be gentle, it's my first... All Poser 4. DivX 5
thgeisel posted Sun, 13 October 2002 at 3:28 PM
nicelol the killertree!
TrekkieGrrrl posted Sun, 13 October 2002 at 5:17 PM
Heh I discovered I actually HAD a prgram that could put sound on a videoclip, so now it's even better G
Same link
Jackson posted Mon, 14 October 2002 at 10:36 AM
Very nice! May I ask the frame rate?
zalmegra posted Mon, 14 October 2002 at 10:59 AM
Cute. I think my first one was making poser nerd dip at the hips...and no sound. So you're ahead of where I was.
TrekkieGrrrl posted Mon, 14 October 2002 at 2:41 PM
Jackson, the framerate is the default 30. I wasn't sure what it would mean to change it, so I didn't G
Jackson posted Mon, 14 October 2002 at 7:41 PM
If you decrease the frame rate the file size and quality also decrease -- as long as you don't change the time.
Bobasaur posted Tue, 15 October 2002 at 10:52 PM
Nice job ernyoka1! My first animations were simply spinning things and moving them. FWIW, if you're simply creating for the web, a frame rate of 15 (or even as little as 12) will work fine. It creates a smaller file size. Technically speaking, the motion doesn't appear quite as smooth as 30 frames per second, but it's a very common frame rate and is quite acceptable. Be sure and set your frame rate before you create your animation or you will end up slowing down (or speeding up) your characters' movements. If you want to change a frame rate after you've got everything animated, you'll have to use the "retime animation" feature.
