Forum: Bryce
Subject: Bryce Format
fileman_1 opened this issue on Oct 13, 2002 ยท 11 posts
fileman_1 posted Sun, 13 October 2002 at 3:34 PM
Does anyone know how to change a file from the Bryce native format to a .obj or similar?
Hawkfyr posted Sun, 13 October 2002 at 3:37 PM
It can't be done with native objects(Primitives). nor booleand groups. Only lattice,terrains,and previously imported objects can be exported to .obj. again..no booleans It would be nice though. Tom
“The fact that no one understands you…Doesn’t make you an artist.”
Jausse posted Mon, 14 October 2002 at 2:43 PM
No booleans? I've saved all the objects I've created as .obj files with the export option. Josselin :-)
Hawkfyr posted Mon, 14 October 2002 at 2:52 PM
a boolean in Bryce does not modify mesh/geometry. A negative boolean only tell Bryce's renerer "Don't Render This". If it does export,..the negative will be visable. Perhaps this was changed in Bryce 5 but I would doubt it.It's just the way Bryce handles it's booleans as far as I know. But..I've been wrong before. 8 ) Tom
Jausse posted Mon, 14 October 2002 at 3:35 PM
I suppose It's because of Bryce 5, I didn't try it with Bryce 2. I just created models with booleans (positive & negatives), added them to my objects library and then exported them as objects. It also worked with objects created with metaballs. Josselin ;-)
Aldaron posted Mon, 14 October 2002 at 5:18 PM
You didn't export as .obj then. You exported in Bryce's native format of .obp Those are different formats
Jausse posted Mon, 14 October 2002 at 11:33 PM
My mistake, I didn't read properly. Silly me ;-)
Allen9 posted Tue, 15 October 2002 at 1:23 PM
This question comes up SO frequently, in so many variations, there really should be a BIG sign at the top of the forum saying "Before you ask, NO, you CANNOT export Bryce-created objects to another format. Maybe in the next version."
catlin_mc posted Tue, 15 October 2002 at 7:48 PM
If you make an object in Bryce can it be exported as another formst before you've turned it into a Bryce preset ?
Aldaron posted Tue, 15 October 2002 at 8:07 PM
No Bryce primitives can be exported, period. Only terrains, lattices and rock may be exported.
Hawkfyr posted Tue, 15 October 2002 at 9:56 PM
"No Bryce primitives can be exported, period. Only terrains, lattices and rock may be exported." And previously imported models too. 8 ) Tom
