Subject: Black Render... :(
KimberlyC opened this issue on Oct 13, 2002 ยท 9 posts
KimberlyC posted Sun, 13 October 2002 at 10:06 PM
I keep getting a black render when i add lights..or if i keep changing lights..and then render...anyone know what is going on...i have had that problem before..but it fixed itself..after i restarted..but its not fixing now.... if anyone could help..i'd be very greatful :) Kim
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
dcasey0284 posted Sun, 13 October 2002 at 10:24 PM
I just got the same thing. Don't know what's causing it.
X1 posted Sun, 13 October 2002 at 10:30 PM
This is TalleyJC on X1's machine.... I've noticed the black render if you have a model using P5 materials but attempt to do a p4 render.... just a possibility
KimberlyC posted Sun, 13 October 2002 at 10:33 PM
I'm using Poser 4.. :)
X1 posted Sun, 13 October 2002 at 10:38 PM
Whoops sorry..... Being P5 is so bug ridden I still use it to.... I had that problem with p4 only a few times as well.... What I found was that the shadow maps that were generated swamped the windows swap files in some weird way and not often..... but what fixed it was reboot or defrag your hd..... (both tend to correct the swap files)
lalverson posted Sun, 13 October 2002 at 11:39 PM
Are sure the camera is not in a wall? if it is then that is why
Spit posted Mon, 14 October 2002 at 1:06 AM
It's a Poser lighting bug. Happens when changing light sets from targeted spots to omnis. Only solution is to close Poser and open again. I even think the bug survives a trip to a saved pz3. I think Blackhearted figured it out but I don't remember the details.
VIDandCGI posted Mon, 14 October 2002 at 1:55 AM
Maybe restarting poser to factory default settings will help in the short term to get you rendering again.
Sue88 posted Mon, 14 October 2002 at 7:25 AM
I've had a similar problem several times and what helped me was to delete all the lights in the scene, then load a new light set. I hope this helps! Sue
