Subject: Exporting Wavefront or 3DS meshes in Poser 5 - Bug or my system ?
aheinz opened this issue on Oct 14, 2002 ยท 3 posts
aheinz posted Mon, 14 October 2002 at 10:27 AM
Hi everybody ! Whenever I try to export P5 crashes with a C-Exception. Do to you experience this also, hence is it a(nother) bug ? I ask here in the forum, because P5 is working more or less stable on my machine, with above exception. I can imagine that the CL people are under a lot of pressure, so I do not want't to bother before I did not have more information for them. My System: P5 + SR1; P5/1.7GHz; 512GB RAM running WinXP (without SP1) Thank's in advance and have a niche day ! Arthur
thgeisel posted Mon, 14 October 2002 at 10:56 AM
just tried it without problems,but have a look at www.poserpros.com in the p5tutorial section, someone had a similar problem,and a workaround
diana posted Mon, 14 October 2002 at 3:46 PM
I'm running a P4 1.7GHz, WinXP Home w/o SP1, 512MB RAM, Poser 5 with SP1. I have exported several wavefront obj files, no C exception errors yet during them, although I have had a few in other areas. I just fired up Poser 5 again today while online now and exported a pair of boots as 3ds and no problems. I checked out the model in Deep Exploration and it looks fine there so the export worked properly too.
