Willowjune opened this issue on Oct 16, 2002 ยท 5 posts
Willowjune posted Wed, 16 October 2002 at 10:29 PM
I have Poser4 and am able to create morph targets in Rhino for Posette's head (I'm making an older character and have done hooded eyes, undereye softening, jowls, etc). No problem with these. Posette's geometry file to Obj3dm, load into Rhino, delete all but head, make changes, export as .obj file, open Poser, put Posette into the document window, click on Object -> Properties -> add morph target, and there's the parameter dial, which works fine. But when I try to do morph targets on the abdomen or hip parts, I have a problem. When working in Rhino, I'm very careful not to add or delete control points and to not move anything around the edges. Then I follow the same procedure as above, but I get "Incorrect number of vertices." Back when I couldn't get anything to work, Roy G. suggested importing the part from Rhino into Poser as a prop, exporting it as a morph target, then adding as morph target. However, that doesn't work for me. Any suggestions?
