mprr opened this issue on Oct 16, 2002 ยท 13 posts
mprr posted Wed, 16 October 2002 at 10:44 PM
I just upgraded my system to an AMD 2.0 with 516 Megs of memory. When I try to import an object into Bryce 4 I get an out of memory error 2/3 of the way into the import. I never had this problem with my AMD 450 with the same memory. Just for the experience, I downloaded the trial version of Bryce 5 to see if I liked it better. I also got the same error. Thinking well the obj file is 48 megs, I tried a much samller object and got the same result. It seems to like files samller than 5 megs in size. My suspicion is that something changed in windows when I put the upgrade in. So far Bryce is the only graphics program that is causing this error. Poser and RDS haven't had any problems and PS works like a dream. Any ideas? Thanks. Fred
AgentSmith posted Wed, 16 October 2002 at 11:17 PM
What Operating System are you using? Is it just your memory you upgraded, or your OS also? 48Mb mesh??!! What is it, a 1:1 scale planet earth?
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
ttops posted Wed, 16 October 2002 at 11:18 PM
Hi Fred, Switch your computer off and remove all power cables attached to it. Take the side panel off and locate the clear cmos/bios jumper. It's usually close to the chip (award bios). If you have a manual for your motherboard you can check it out. Clear the bios by setting the jumper to 1-2 for a few seconds, then short 2-3 for normal operation. When you switch you computer back on go in to the bios setup by holding down the delete key at start-up. Configure the standard settings and go in to advanced settings. Here you can set the CAS latency (Cl cycles) and ROW precharge (trp cycles). Make sure you know what kind of RAM you are using (what Cl). If you give the make and model of your mother board and Ram I can tell you what these settings are. Another thing that may be causing this could be the virtual memory setting in windows. Again I would need to know what operating system you are using. Hope it helps, TT.
mprr posted Wed, 16 October 2002 at 11:39 PM
Thanks for the quick reply! It is an AZZA KT133av motherboar with XP 2.0 CPU. The memory is 2 sticks of pc133 256mb. I am using windows ME. Also I upgraded the video card to a evga gf4 mx420. I do have the systems board manual. The folks down at the shop I bought it from did basic settings. I'll check the items you suggested. Thanks again. Fred
ttops posted Thu, 17 October 2002 at 12:14 AM
Attached Link: http://www.azza.com.tw/Layout.asp?Page=Products&K=89
mprr posted Thu, 17 October 2002 at 12:16 AM
Thanks TT. I'll let you know how this works out.
mprr posted Thu, 17 October 2002 at 12:40 AM
The meg size showed as 48 megs when I got the information box. I was a little surprised too since the majority of the mesh is straight forward ie cubes, cylinders, etc. However, the high polygons occur in a cube that I turned into a pyramid with an indent at the top. I used 4 of these and grouped the four of them. The count shot up significantly. I'm still very much learning to make meshes so I obviously did something wrong. Fred
lsstrout posted Thu, 17 October 2002 at 12:32 PM
I'm not sure where the settings would be for this on PC, but on my mac I had to increase the alloted memory size for the program itself before I could do much with it. On the mac, you select the icon for the program and adjust the settings from there. Good luck with the memory problem.
mprr posted Thu, 17 October 2002 at 1:13 PM
TT I did the resets and still get the same problem. lsstrout probably has the right solution. Problem is that on a PC, this is a windows file rather than a convienient setting. Poser and Bryce seem to be using the same file. Amorphium, PS 6.0, RDS 5.5 GMAX doesn't have a problem with the memory. I seem to remember making a change in a file way back when to solve this problem Problem is I don't have my notes. Thanks
Erlik posted Thu, 17 October 2002 at 2:16 PM
Unfortunately, you can't allocate memory to programs on PC. Umm, what's the size of your virtual memory? It should be 1.5 times RAM, ie 768 megs. Also, have you installed drivers for your new motherboard? That would have changed in Windows when you changed the motherboard.
-- erlik
MightyPete posted Thu, 17 October 2002 at 3:45 PM
Put the object in the root of a drive and try again. Let me knw if it worked.....
catlin_mc posted Thu, 17 October 2002 at 5:27 PM
You can allocate memory to programs if you are using Windows XP. Press Ctrl,Alt,Delete, the Task Manager opens, go into Processes, right click the process you want to allocate more memory to, go into Set Priority and set it to high. Do not close the Task Manager window just minimize it while the allocated program is running. And there you go, whatever program you allocate the memory to will take over the entire system if it wants.
ttops posted Fri, 18 October 2002 at 12:11 PM
Check out your virtual memory settings. Control panel/System/Advanced/performance options if not you can use the Help files for locating it. Also known as the page file or paging. Windows uses this file as extra RAM when files don't fit in to RAM. Are you experiencing any lock-ups playing up to date games? If you are, then it's definitely a problem that you have to solve through your bios. If not, check out your virtual memory settings. It's always a good idea to check for any bios updates just in case there are any glitches/bugs that have been sorted out with the bios you are using at the moment. You can update/flash your bios using the link provided from my previous post. That's the official site for your motherboard. Take care when flashing your bios; if you do it wrong you'll end up with a dead motherboard. TT.
