Subject: Can we merge two poser scenes?
Himico opened this issue on Oct 17, 2002 ยท 8 posts
Himico posted Thu, 17 October 2002 at 5:38 PM
For instance, Bryce has Merge command. All objects from the guest scene are brought into the host scene in the same position they previously occupied.
sirkrite posted Thu, 17 October 2002 at 6:02 PM
Try Import, Poser Document Prop.
CryptoPooka posted Thu, 17 October 2002 at 8:08 PM
Import is a great tool. You can create a character dressed a certain way that you want to use in several scenes for continuity, and manage to keep all clothing and props attached without having to re-create the outfit over and over. Or do the same thing with a set.
Lisas_Botanicals posted Thu, 17 October 2002 at 9:05 PM
Attached Link: http://www.mysticalmodality.com/html/tutorials/complexscene.html
Here's a tutorial I created using several poser scenes together. :) Hope it helps! Lisa
Himico posted Fri, 18 October 2002 at 10:36 AM
Thank you, sirkrite, CryptoPooka,and LisaB. It was what I wanted to have. Lisa, I could not reach to your page. Is the link accurate?
Lisas_Botanicals posted Fri, 18 October 2002 at 10:42 AM
Yes, the link is accurate but my host was purchased by another company and in the process of moving servers my site is available/not available almost hourly. Frustrating for sure. Try later? :) Lisa
Hiram posted Fri, 18 October 2002 at 11:57 AM
It does??? ::runs for manual, trips over phone cord::
lesbentley posted Fri, 18 October 2002 at 12:15 PM
You could try changing the file extention of a pz3 to cr2, then load it via a figures pallet.
