Subject: Newbie question: props tutorial?
ghoyle1 opened this issue on Oct 26, 2002 ยท 2 posts
ghoyle1 posted Sat, 26 October 2002 at 7:34 PM
Hi there, I'm trying to find out how to combin severl Poser props primitives into a single prop. Is there a tutorial on how to do this? Or at least some advice? TIA, Guy
geep posted Sat, 26 October 2002 at 7:59 PM
Sure, just get the props you want to combine exactly where you want them and then ... [menu] "File" ---> "Export" ---> "Wavefront Obj..." In the "Hierarchy Selection ... UNcheck the "Universe" and then ... check the props you want to combine. Then "export it to "yourfilename.obj" Now, when you "import "yourfilename.obj" it will be ONE object and you can save it in your props library. Ok? cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
