Subject: Fix for one sided geometry in MilDragon?
jbtrimar opened this issue on Oct 27, 2002 ยท 7 posts
jbtrimar posted Sun, 27 October 2002 at 6:05 PM
I was wondering if anyone new how to fix the one sided geometry on the wingflaps of the MilDragon for export to 3D Studio? I did a search in this forum but did not see if it was discussed. Thanks.
Cage posted Sun, 27 October 2002 at 7:04 PM
Well, you could use the grouping tool to spawn props from the one-sided portions, reverse the normals of those props, and combine the props with the original geometry. Not sure how well that would work out.... Or you might be able to use Objaction Twoface, which is available in the FreeStuff, somehow.
jbtrimar posted Sun, 27 October 2002 at 8:25 PM
This looks like it will work (Objaction Twoface). Just gonna be a LOT of work :-)
OpticalSingenoid posted Sun, 27 October 2002 at 10:27 PM
There's an easier way! In Max, just go into the Material Lab & in the proper material(wings), just check "2 Sided". Works everytime! ;-) Marco
GROINGRINDER posted Tue, 29 October 2002 at 12:10 AM
UV Mapper will do it also.
jbtrimar posted Tue, 29 October 2002 at 8:48 AM
Marco had the answer. Thanks marco. I use Maximum Pose to transfer my animations into MAX, so I had to pull the material from the model and go searching for the Wing Transparency, but once I clicked on 2 sided, all my problems went away!! Marco, you rule! Joe
OpticalSingenoid posted Tue, 29 October 2002 at 8:59 PM
:-)) Well, i'm just glad it worked! I've been using Max since it's Dos version. But, i keep finding new tricks... :-) Don't be afraid to try out all the buttons!! Never tried Maximum pose, But from what my friend told me, it makes life a lot easier! Konan Rules!! ;-) And if you ever have a ? concerning Max, then just message me! Later! Marco
