Subject: Prop Question
ghoyle1 opened this issue on Oct 30, 2002 ยท 13 posts
ghoyle1 posted Wed, 30 October 2002 at 8:30 PM
Is it possible to make something like a hollow cylinder (like a tube) from Poser primitives, or is another program (like Bryce or Lightwave) required? Guy
lordbyron posted Wed, 30 October 2002 at 8:44 PM
Why not use the grouping tool to cut off the ends of a cylinder? --lb
EricofSD posted Wed, 30 October 2002 at 8:46 PM
Attached Link: http://www.annsartgallery.com/freeprop.html
Bryce wouldn't work for you because the primitives don't export. But there are a ton of free modelers out there that will do the trick for something as simple as this. If you're on a PC, then Metasequoia will do it easy enough and give you some extra things to play with as well.
Niles posted Wed, 30 October 2002 at 8:47 PM
Try the Torus... adjust the fattness, scale the x,y,andz
ghoyle1 posted Wed, 30 October 2002 at 9:06 PM
Cutting the end off a cylinder would work to some degree, but I'd like there to be some thickness to the wall of the cylinder. The torus might work to some degree, but I don't want the ends of the cylinder to be rounded. I'll take a look at metasequoia. Know of any other free modellers that might work? Thanks! Guy
PhilC posted Wed, 30 October 2002 at 9:16 PM
Attached Link: http://www.philc.net/freestuff_archive.htm
I have some extra Poser primitives if that will help.
Niles posted Wed, 30 October 2002 at 9:18 PM
when you say the ends of the cylinder do you meen the lip? if so, try using a second cylinder for the lip.
wgreenlee1 posted Wed, 30 October 2002 at 9:49 PM
Wings 3D Excellent Poser assistant!
geep posted Wed, 30 October 2002 at 9:53 PM
Use 2 cylinders. Export one and then import it with reversed normals. Use this for the inside of the "tube." Then take 2 torus and flatten them to fill the small gap between the "inside" and "outside" cylinders. Export the "parts" then import as 1 prop. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
ghoyle1 posted Wed, 30 October 2002 at 10:36 PM
Whoa. That's very neat! Never thought of that. Thanks! Guy
EricofSD posted Wed, 30 October 2002 at 11:23 PM
yeah, there are many modelers that are free out there. visit the site I sent you and play with the links. hammapatch, spatch, wings, etc. If you go to the amapi forum here, there's a link to the amapi 4.15 freeware version and that's a very powerful modeler for free. If you want to buy modelers, my recommendation is the dvgarage kit that comes in a popup screen when you visit www.universe3d.com Its $200 and comes with a very powerful animator, modeler, and organic modeler (amorphium pro). You'll need to be on a mac or NT system to use it. I can't say enough about Universe Modeler!!!
jenay posted Thu, 31 October 2002 at 11:14 AM
Attached Link: http://www.joes3dfantasyworlds.com/down/primitives/primitives01.htm
hi - i have a morphing ring/tube in my download area at: (it's a bit edged and the textures are somehow distorted. but you can scale it at your taste, then export it as a single prop and apply a new texture if desired ...) i used the uvmapper tool lithunwrap (downloaded at: http://www.geocities.com/lithunwrap - sorry don't know wehter the link still works ...) withihn this program you can create a tube of variable length and thickness. hope this helps :) joe
maclean posted Thu, 31 October 2002 at 4:38 PM
I have 3 packs of weird primitives at 3D Commune Freestuff. The 1st one has a tube, semi-tube and quarter tube. Each pack has around 30 bizarre shapes that Poser doesn't have. They're called Prop-o-rama 1,2 and 3. Search for 'maclean' if you need them. mac
