Forum: Bryce
Subject: Poser to Bryce
Infra5 opened this issue on Oct 31, 2002 ยท 6 posts
Infra5 posted Thu, 31 October 2002 at 2:07 PM
I was wondering how do I make the hair on poser people look more real in Bryce?The eye lashes the hair the fine hairs on the arms and body and eye brows? http://www.renderosity.com/viewed.ez?galleryid=270871&Start=1&Artist=Infra5&ByArtist=Yes
this is all I have right now done and I was hoping to finish her off by making her look more real.
Dark6Rayden posted Thu, 31 October 2002 at 2:19 PM
You have to use transparent maps just like in Poser. They a bit tricky to apply at first, but you sure will get it fast. :)
Rayraz posted Thu, 31 October 2002 at 2:20 PM
I'm nopt really into poser, but I think that eye lashes are normally made with a texture and a trans-map. I think you could try that too with the hair. And maybe, if you have the software. you can import the poser figure into C4D (I've heard that it does much better imports than Bryce) and add hairs with a plug-in. There's a plug-in that makes hair from polygons. I don't know how it's called, but maybe someone else can help you with that. If you make the hair from polygons in C4D than you can export these to bryce. It's probably not the most common way of doing it, but I can't think of anything else at the moment. Also photo-textures make the poserfigure look more real and lighting can add a lot to the figure.
(_/)
Rayraz posted Thu, 31 October 2002 at 2:21 PM
Oops! 'nopt' should be 'not'.
(_/)
Erlik posted Thu, 31 October 2002 at 5:27 PM
Poser 5 comes with several transmaps, and I believe it was the case with Poser 4, too. But only for the hair and lashes, possibly for the eyebrows, too. For the rest, you're on your own. You can add body hair to the texture, or use a bump map: http://www.lynescreations.com/brycebump.htm Or create your own texture: http://www.liquid2k.com/millennia/tutorial.htm Otherwise, check Jelisa's tutorials for painting hair: http://www.fignations.com/jelisa/tutorials/tutorials.html BTW, Google gives tons of hits on Poser texturing tutorials (put the two lines together and remove extraneous spaces): http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=POser+texture+tutorial&btnG=Google+Search
-- erlik
Patrick_210 posted Thu, 31 October 2002 at 11:14 PM
Attached Link: http://www.castironflamingo.com/tutorial/grouper/index.html
Try using Grouper to import Poser to Bryce, Makes it easier.
