Luthoricas opened this issue on Oct 31, 2002 ยท 5 posts
Luthoricas posted Thu, 31 October 2002 at 2:21 PM
I have created a new figure which does have a left and right hand. However, if I select either the LHand Camera or the RHand Camera, they point off into empty space. How do you get the RHand Camera and LHand camera to point to their respective hands ?
Little_Dragon posted Thu, 31 October 2002 at 3:39 PM
Hmmm. My cameras work with Sabrina and Furrette, but I used Posette as a joint donor .... The cameras might be keyed to the internal names of the joints. Did you name them "rHand" and "lHand" within the Setup Room? Select a hand, and call up its Properties panel; that'll show you both the label name and internal name.
Luthoricas posted Thu, 31 October 2002 at 4:11 PM
It's on my computer at home (I'm at work). I'm pretty sure I did name them that. I do know I used all lower-case in my naming. Does capitolization matter ?
Little_Dragon posted Fri, 01 November 2002 at 6:42 AM
Yes, it does. Poser can be quite literal in such matters. For instance, Mimic poses won't work on a figure if the head's internal name is "Head". It has to be named "head".
Luthoricas posted Fri, 01 November 2002 at 10:53 AM
Looks like that's what it must be. The hands are named rhand and lhand. I'll change them to lHand and rHand tonight when I get to my home computer. Thanks!
