itsik_m_18 opened this issue on Nov 05, 2002 ยท 7 posts
itsik_m_18 posted Tue, 05 November 2002 at 7:09 AM
mon1alpha posted Tue, 05 November 2002 at 7:20 AM
:) No worries go to Window Document size and then resize your windows size to....say 100x100 and you should be able to move it back to where you want it. Mon ps: if that doesn't work then try setting preferences to factory setting
Kelderek posted Tue, 05 November 2002 at 7:48 AM
itsik_m_18 posted Tue, 05 November 2002 at 8:17 AM
SamTherapy posted Tue, 05 November 2002 at 8:24 AM
You can only load a texture onto the model it's appropriate for. Example - Victoria textures don't work on the standard Poser female, and lingerie textures will only work on the lingerie model they were made for. There are a few exceptions, but they are very, very rare. What texture are you trying to apply to the model above?
PabloS posted Tue, 05 November 2002 at 4:42 PM
Actually Sam you CAN load any texture on any model that will take a texture. It may look odd, but you can do it. itsik_m_18If, I read your description right, try rendering. You usually won't see the texture until it's rendered unless you set the "document" window to display textures (which makes things move slow). I believe the setting is the last button. (Sorry, if I were at home I could ship you a screen shot.)
mon1alpha posted Wed, 06 November 2002 at 3:17 AM
Always ask questions here :) That's how I've learned things here, in fact I'm still learning after 2 years. There are lots of tutorials here as well bye for now Mon
