MaxBeckett opened this issue on Nov 07, 2002 ยท 9 posts
MaxBeckett posted Thu, 07 November 2002 at 7:19 AM
Hi gang, I ran the updater a few days ago and since then Carrara seems to freeze up on me A LOT. I was goign to just reinstall my original Carrara 2.0, but before that I figured I would ask if anyone else has had any problems. One of the times it always freezes up is if I do a quick render inside the assembly room and have a 3d aura on. Also if I abort a final render in the rendering room I get stuck in that room. I can bring down menus and such but nothing actually works and I cant get out. Let me know if any of you have had similar (or not so similar for that matter, difficulties since using the updater. Cheers, Max
bluetone posted Thu, 07 November 2002 at 8:58 AM
Did you do a fresh re-instal before installing the updater? That's what Eovia strongly recommended, and it may be what is affecting you.
MaxBeckett posted Thu, 07 November 2002 at 9:19 AM
Yup. I did the reinstall. Thats actually why I only upgraded a few days ago. I kep forgetting to bring the install CD with me to work. I guess you havent had these problems bluetone? Max
bluetone posted Thu, 07 November 2002 at 9:33 AM
Actually... (looks down sheepishly...) I haven't done the install at all yet! I've been traveling for work, and haven't had a chance to do the uninstall-reinstall thing. But, I remember seeing the procedure mentioned on the web site when I did the download, and thought it might help. Many a time I have upgraded some software, only to find I forgot a step, and now the software dosen't work/serial number is invalid/hard drive is damaged/ the sun is no longer shining/ time has come to a stop/and other nasty things. ;> Hopefully this weekend, I'll have a chance to do my upgrade, but I'll be checking back here first to see if you've had any more luck! Good luck!!
Pinklet posted Thu, 07 November 2002 at 10:39 AM
I got lazy and applied the patch on my old C copy and it seemed to work until I tried to save a rendering and no dialog box would come up. The Fresh Install trick worked and fixed the problem. So I, like Eovia recommend to do the fresh install thing.
Kixum posted Thu, 07 November 2002 at 11:21 AM
I've done a clean install and it works fine. -Kix
-Kix
smcquinn posted Thu, 07 November 2002 at 2:28 PM
I did a "dirty" install over the previous updater and have not yet seen any problems. Windows version.
MarkBremmer posted Thu, 07 November 2002 at 2:52 PM
On the Mac side, OS 10, a clean install is a must. Didn't do the clean install the first time around and had a bunch of issues. After a clean install, everything works well now though. Mark
charlesb posted Sat, 09 November 2002 at 1:50 AM
Hi Max, have you emailed our support (support@eovia.com) ? I haven't heard of anyone complaining of problems with the 2.1 update so far. If you have any particular problem, please report them to us so that we can fix them ! What platform are you on ? Mac ? Windows ? Have you been able to reproduce those problems ? Or was it just random crashes ? Charles Brissart Eovia, Corp.
