obsessedwith3d opened this issue on Nov 08, 2002 ยท 4 posts
obsessedwith3d posted Fri, 08 November 2002 at 3:53 AM
Has anyone gotten PPP(SR-3) and Lightwave 7.5 to play together? When I try to open a .pzz or .pz3 file from within Layout, I get an error message stating that Layout can't open the Poser file. Thanks!
Jaqui posted Fri, 08 November 2002 at 4:44 AM
is the lightwave plugin installed in poser? you may be able to export the scene from poser into lightwave format. ~g~ since the original plugin was for lightwave 7 ( I think), not 7.5 that may be the only option available. using different formats to get the scene imported. but I don't have lightwave on my system so other than the ideas above can't really offer any help
scaramouche posted Fri, 08 November 2002 at 6:35 AM
Hi, obsessed! Go to the LightWave forum for my short tutorial response to your post.
Norbert posted Fri, 08 November 2002 at 11:05 AM
Check the "setuplog.txt" file in your 'Lightwave/Programs' folder, and make sure all the file paths listed, are correct. Also, a "PoserReadMe.txt" file gets installed to that same folder. (or at least, SHOULD have been)
