arabinowitz opened this issue on Apr 07, 2000 ยท 4 posts
arabinowitz posted Fri, 07 April 2000 at 5:44 PM
Anyone know why my computer keeps freezing up with BVH files more than 200K. I have a P2 400Mhz 128 RAM, and the sucker still freezes up with the normal size BVH's. Is there a fix for this I don't know about. I can only use about 10 of the BVH files poser came with.
Serpent posted Fri, 07 April 2000 at 8:22 PM
Hello, I don't believe it's your computer itself that's the problem. I have loaded up 900 frame BVH files on my old Pent 200 with 64 meg. Might be the patch that you are or are not using. You didn't say if it was Poser 4 or 3. Could also be another program interfering like certain Video cards have Display Program shells that run all the time, or do you have compressed hard drives, are you running anti-virus shells? Any of these could be the problem. Try to eliminate all other progs loading into memory and retry the BVH. Let run for a while some of the larger BVH files can take up to 10 min to load during this time it appears to be locked up but really is still working. Serpent
arabinowitz posted Sat, 08 April 2000 at 7:50 PM
Thanks. I'm running a Poser 4. I'll try shutting down virus scan and some other stuff. Lets see what happens. Thanks again. Aharon
arabinowitz posted Sun, 09 April 2000 at 1:03 AM
It worked. Thanks Serpent.
