Subject: strapless Leotard
Butch opened this issue on Apr 07, 2000 ยท 9 posts
Butch posted Fri, 07 April 2000 at 6:08 PM
I have tried to hide the shoulder straps on the leotard and I can hide the front side. But the straps remain on the back. Can anyone tell me how to lose the straps or maybe create a strapless leotard? If you do create a strapless leotard, could you also cut it a little higher on the thigh? Thanks butch
pam posted Fri, 07 April 2000 at 6:22 PM
sounds like a transmap for the one you have is what you need. I will take a peek, and see what I can do. pam
Butch posted Fri, 07 April 2000 at 6:45 PM
thanks. I have fiddled with it for some time now and nothing that I could do worked. butch
pam posted Fri, 07 April 2000 at 8:49 PM
leo_front.jpg You will want to tinker with this, to get the leg openings the way you want. leot_trans.jpg
Butch posted Fri, 07 April 2000 at 9:21 PM
That's it! thanks a bunch. This is great Butch
Butch posted Fri, 07 April 2000 at 9:40 PM
Ok, I stumped how did you get it to work? I keep getting the straps. I know that I am not doing something right, but what? Please walk me through it. I can be a bit dense at times. butch
pam posted Fri, 07 April 2000 at 9:56 PM
no problem, I should have been more specific :-) material.jpg under the render dropdown menu, choose materials. Use these settings, except for the hot pink, normally you would set the color to white if you have a texture.
Butch posted Fri, 07 April 2000 at 9:58 PM
I figured it out just after I wrote the message. Thanks for your help. I forgot to set max level. I still had it set on 0. thanks again butch
Butch posted Fri, 07 April 2000 at 10:36 PM
Posted a new message check out what I am working on.
