Cage opened this issue on Apr 08, 2000 ยท 6 posts
Cage posted Sat, 08 April 2000 at 12:54 PM
I have developed some sort of problem in trying to download files. This only happens with some downloads. Most are okay, but those that have a problem continue to have the problem, no matter how many times I attempt to download. It does not seem to be a problem with the files I am attempting to download, nor with the drive to which I am attempting to download. When the problem occurs, the download behaves normally, up until the point when it would usually be saved to the disk. I then get the following message: SYSTEM FILE ERROR (1026) Download could not be completed. I have not been able to find any record of error in Windows. I am, God help me, on AOL... could this be an ISP thing? I am asking here in desperation because the problem has come to affect files in the Free Stuff, at 3DCC, and at Dedicated Digital. :( PLEASE HELP!
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
nerd posted Sat, 08 April 2000 at 3:02 PM Forum Moderator
Start AOL, login and minimize it. Start Internet Explorer. Go to renderosity (or where ever) and see if you can download now. Things will look a little different but it should work. Note you can also use Netscape this way. Hope this helps.
robert.sharkey posted Sat, 08 April 2000 at 3:15 PM
I use in the office IE4.0/IE5.0 and at home NS3.04 i promise you it works very well. SHARKEY
Cage posted Sat, 08 April 2000 at 5:19 PM
Wow! That did the trick. Thank you immensely! Can anyone explain what has just happened here, and why it has begun happening only recently? Is it definitely some problem with the service provider? Thank you!
Crescent posted Sat, 08 April 2000 at 10:42 PM
It's an AOL thing. I've heard of lots of people having to do that same trick to get anything to work. AOL = Always Out of Luck!
Cage posted Sat, 08 April 2000 at 10:48 PM
I thought it was A**hOLe, if you will pardon the vulgarity. I did not begin to have the problem until recently... about the time of the Time/Warner merger.... Hmmm.... Thank you, everyone, for your help and patience!
