Subject: Full body morph for P5 Judy
MindVision-GDS opened this issue on Nov 12, 2002 ยท 18 posts
MindVision-GDS posted Tue, 12 November 2002 at 8:54 PM
Sorry Marvlin..took a bit longer to make it work with the facelab.
Its in Poser freestuff characters...enjoy :)
-M-
nakamuram posted Tue, 12 November 2002 at 9:21 PM
I installed your Morph Files. When I load Julie I get prompted for Judy2b.obj. There is no Judy2.obj in your zip file.
Kelderek posted Wed, 13 November 2002 at 3:23 AM
nakamuram: The Judy obj file should be on your system if you have Poser 5 installed. If you have Poser 4 or earlier versions, you cannot use these morphs, since the Judy figure is in Poser 5 only.
MindVision-GDS posted Wed, 13 November 2002 at 4:09 AM
Sorry my bad..I put Poser5 in the title now. Judy2b is naming I used when reshaping Judy's mesh..if anyone else have a problem with this file please let me know. -M-
Lunaseas posted Wed, 13 November 2002 at 10:21 AM
Thank you...she looks great!
Xurge posted Wed, 13 November 2002 at 11:01 AM
Very neat, works for me. Thank you.
marvlin posted Wed, 13 November 2002 at 4:27 PM
Hmmm! Well I feel a right plonker! I'm having a spot of boffa mate. I'm being asked for the judy2b.obj as well, erm..help! By the way, thanks Mindvision, your a pal, as soon as I get this babe fired up she'll be featured in my next story with a credit to yourself. That's when I get her fired up that is, by the way a special thanks to xurge & Lunaseas for irritatingly having no trouble and making me look a div :-) MARVLIN
i7 5930K 3.60Ghz | ASUS X99-S Motherboard | Crucial Ballistix Sport 32GB DDR4 2400MHz RAM | NVIDIA TitanX | Antec 1000w Power supply | Windows 10 x64 Home
MindVision-GDS posted Wed, 13 November 2002 at 4:32 PM
Hmmm..I deleted my own files and unzipped in poser folder too without trouble..I dont like the sound of judy2b.obj..can u tell me exactly what u did?
marvlin posted Wed, 13 November 2002 at 4:44 PM
I unzipped the file into the same folder I downloaded it to, them I opened the C/Labs folder to reveal the runtime folder, I then dragged the libraries folder from the unzipped folder onto the runtime folder and clicked yes to overwrite existing files, Then I clicked on julie in libraries and was asked for the judy2b object, I tried using the p5 nude woman object with quite scary results.DoH!
MindVision-GDS posted Wed, 13 November 2002 at 5:23 PM
Ok..I found the error and I'm afraid its my bad..I will fix asap..
marvlin posted Wed, 13 November 2002 at 6:31 PM
Okey Dokey.
nakamuram posted Wed, 13 November 2002 at 7:49 PM
Anxiously waiting... for Julie and my FireFly Render. Actually, with the OBJ file things should also work in P4...
MindVision-GDS posted Wed, 13 November 2002 at 7:57 PM
Ok..found the problem and hope I solved it..please let me know if this works ASAP so not another 700 people will download a bad file.. -M-
MindVision-GDS posted Wed, 13 November 2002 at 8:05 PM
Oh..its in poser freestuff characters...dont mind me..its late :)
dcasey0284 posted Fri, 15 November 2002 at 2:05 AM
sorry, I'm still having the problem. What is the object file for Judy? What is the filename used in the cr2 file?
MindVision-GDS posted Fri, 15 November 2002 at 4:56 AM
{version{number 5}
figureResFile :Runtime:geometries:P5NudeWoman:P5NudeWoman.obj
This one should work..did you restart Poser after overwriting the first file?
dcasey0284 posted Fri, 15 November 2002 at 5:03 AM
yep, I got it to work. Thanks! Much better than the default Judy!
MindVision-GDS posted Fri, 15 November 2002 at 5:06 AM
PFEW! I promise I will fully learn a new application before I upload anything next time :) Thanks for the feedback. -M-
