Subject: RoyRiggsPhiBuldrProblem
dyan opened this issue on Nov 13, 2002 ยท 5 posts
dyan posted Wed, 13 November 2002 at 5:54 PM
Downloaded Phi Builder 2 times, finally the 3rd time it "took". It said to put in the directory where poser 3 is installed. O.K.-Did that- C-program-metacreations. Not good! O.K.-tried c-program-metacreations-poser3. O.K. still not good.! even tried to put it in geometries! Still said that dialog box thing-then phi opend up, tried to use it anyway, but said obj couldn't be found, da! Downloaded 3 tutorials, even used a pre-made phi from elsewhere, but-Still that dialog box.What/where does it go, what am I doing wrong? Embarrassing.
TygerCub posted Wed, 13 November 2002 at 6:42 PM
Two things that might help: 1) Place the PhiBuilder exe file in the file where the Poser.exe resides. They must be in the same folder together. 2) Make sure you open the object from the Poser Geometries file. Other than that, I can't think of anything else that would be wrong. Good luck.
bloodsong posted Wed, 13 November 2002 at 6:43 PM
heyas; um, is your poser3 in c:programmetacreations? find your poser.exe and put phibuild.exe there with it. hmmm... it should work if you get it there :/
Ajax posted Thu, 14 November 2002 at 1:39 AM
When you build your PHI file, make sure it has the same name as your obj file (except for the extension) and make sure it's in the same directory as the obj. Poser will often tell you it can't find the obj otherwise. Just thought I'd mention that since it took me a long time to figure that one out when I started building cr2s.
View Ajax's Gallery - View Ajax's Freestuff - View Ajax's Store - Send Ajax a message
dyan posted Fri, 15 November 2002 at 12:56 PM
Haven't been here for a couple of days, my cat died.Wasn't up to doing anything.My poser exe is in C/programs/metacreations/poser3. I did put it in there. Thats when the dialog box came up. Will try again, and maybe the obj name I changed and thats the problem. Will try tonight, will let you know.-Thank you all.
