neftis opened this issue on Nov 13, 2002 ยท 10 posts
neftis posted Wed, 13 November 2002 at 6:40 PM
hello everyone! I am trying some new morphs in poser but I got a strange exploding results when I use the dials...do you know what causes this and how fix it??(if it is possible to fix) HELPPPpppp !:)
Patricia posted Wed, 13 November 2002 at 7:09 PM
The other day, I tried to give Cecily a pair of dimples and exploded her cheeks instead! My hand had slipped on the mouse and spun the dial way too far. That's the only way I've ever done it....not to say you haven't discovered a new one ;)
sirkrite posted Wed, 13 November 2002 at 7:18 PM
Whatever program you used to make the morph in, you most have move the object while you were working on it. That does causes that to happen. I don't think it can be fixed. You will most likely have to make it again.
neftis posted Wed, 13 November 2002 at 7:19 PM
neftis posted Wed, 13 November 2002 at 7:20 PM
nerd posted Wed, 13 November 2002 at 11:45 PM Forum Moderator
The techincal term is "Winding Order" The order the vertex appear in the OBJ file is different betreen the Morph OBJ and the base OBJ. This usually happens if vertexes are added or deleted from the model during the morph creation. Also some nodeling programs will reorder the vertex no matter what you do.
steveshanks posted Thu, 14 November 2002 at 4:07 AM
What app you using to morph in neftis?, the problem looks like nerd says as i get the same results in cinema 4d, but it can be got around...Steve
neftis posted Thu, 14 November 2002 at 1:03 PM
Thanks everyone! Steve I am using lightwave modeler to morph and from it I export in obj format. I suppose I have to redo my morphs then:( But at least, i love to do the job! hehe
steveshanks posted Thu, 14 November 2002 at 1:26 PM
there was a thread a day or two ago, a guy asking the best app to make morphs in and a few replys where LW, might be worth hunting that thread down and asking there, i was hoping you'd say cinema so we could fix it easy ;o)..Steve
daeve posted Thu, 14 November 2002 at 7:56 PM
I had the same problem using Lightwave to make morphs. I get around it now by killing (not deleting) all the polygons (leaving just the points) before exporting. Works fine for me. dAeve
