Crakmine opened this issue on Nov 14, 2002 ยท 7 posts
Crakmine posted Thu, 14 November 2002 at 7:07 PM
I'm looking into buying a Nikon film camera, and theres only one thing making me want to go back to canon is the lack of the amazing Macros that canon has. However, I came upon the Bellows Units, with up to an astounding 11x life size, and with another it doubles that, so, being a far more than avid Macro lover, I went completely insane, however the Nikon site only lists the Bellows, PB-6 as only an attachment for the F5, a -quite expensive- camera, now, if need be I could buckle down and get the f5, however with any preferance I'd like a cheaper one(even just an F100, one step down), so, my question is, does anyone know if the Bellows work on other Nikon SLR cameras, or are there other like systems that work on them? Thanks in advance, mainly for actually reading all this.
Rork1973 posted Thu, 14 November 2002 at 8:56 PM
Rork1973 posted Thu, 14 November 2002 at 8:58 PM
Wolfsnap posted Thu, 14 November 2002 at 9:14 PM
Stick the smaller power pack (MB21?) on the body and you don't have to worry about the curve at the bottom - makes for a smaller package to lug around, too. I do fully agree, for 35mm macro work, IMHO you simply cannot do any better than the F4 (macro work is somewhat my specialty) The PB-6 works fine on an F4. You might like this combo - a 300mm with a nikon 6T lens mounted on front (no, the step down rings don't create any vignetting) - add to that about 25mm extension, and you're shooting life-size - but from about 3 feet!
zardoz posted Fri, 15 November 2002 at 4:29 AM
I agree with Rork and Wolfsnap, macro with the F4 works like a charme.
Just bought me a used Novoflex bellow and a 12mm Extension tube.
With my 24mm lens reverse mounted it gets me down to aprox. 7:1.
Still waiting to get the first film back.
AFAIK, you'll need a 12mm extension tube to mount the bellow on all modern Nikon AF cameras,
for sure for the F4 and F5.
A cheaper way is to use extention tubes, a reverse adapter (BR-2A) and a good wide angle lense.
here are some test shots with this gears:
http://t-bernt.de/Foto2/macro.jpg
If you just want to shot macros up to 1:1, a good macro lense will do the job,
even the Sigma and Tamron macro lenses gets good reviews.
cheers
Thomas
Alpha posted Fri, 15 November 2002 at 6:18 AM
As all Nikor lenses and adapters are made to fit all Nikon SLR bodies, I doubt the PB6 uses a different mount. The trick to remember is that any body that integrates a verticle grip will require that you rotate the bellows to what would be their verticle position before attaching them. Once mounted to the body, they can be rotated freely without any hassle.
BTW... After tested the F100 and comparing it to the N90s, I purchased a new N90s. The difference in price will cover more than half the cost of a bellows or micro-nikor, and the performance difference could not justify the price difference. Of course I rarely use all the bells and whistles as most of my shooting is done in manual mode.
Crakmine posted Fri, 15 November 2002 at 8:40 AM
Gah! Dandelion! Thats it... I think I have to buy it now
