Subject: P5 Material Tip - Inverting Greyscales
yggdrasil opened this issue on Nov 15, 2002 ยท 12 posts
yggdrasil posted Fri, 15 November 2002 at 7:56 AM
I can't recall seeing this mentioned before, but recently I had the need to use the same greyscale image in both positive and negative versions on the same material. Rather than use two bitmaps, I looked for a material room method of inverting the image, and the above shows my solution using two math nodes. Hope someone finds this useful. -- Mark
Mark
