Subject: Same skin color for face and body in P5.
Doorknob opened this issue on Nov 19, 2002 ยท 4 posts
Doorknob posted Tue, 19 November 2002 at 8:49 AM
  1. I create a new nude P5 figure (Judy/Don) 2. I go to the Face Room and create a face for my figure, then I apply the face to the figure. The problem : the color of my figure's skin face is completely different from my figure's body color. I believe this problem can be fixed in the Materiel Room, but have'nt been able to figure it out yet. The only partial solution I managed to work out is to apply the body texture on the face, which could have been cool if I wanted to create a person with nipples on the forehead, but sucks otherwise. Any Ideas? Doorknob P.S : I have some 30 Megs I'm not using. If anyone wants to hold their freebies there, mail me at doorknob2222@hot_REMOVETHIS_mail.com
Velen posted Tue, 19 November 2002 at 9:15 AM
Hi once you make the face in the face room click applie shape only, then poser will use the default texture for the head. other wise you need to reload the default head texture. hope this helps Laters Vel
EvoShandor posted Tue, 19 November 2002 at 4:30 PM
Here's an idea... I'm using P4 experience though, not sure if this'll work in P5...try using your color select on your light settings w/the eye dropper tool. Select the color of the neck/head @ the bottom of the imported texture. your light will change, but it also adds that color to the palette. Now, go into your color settings, and add that color as a custom color, save, exit. then change the color of your body in the materials settings to that custom color. Would that work in P5? Evo
EricofSD posted Tue, 19 November 2002 at 9:47 PM
this is a well cranked on problem. You can alter the body skin to match the head, but there is a neckline thing that can only be fixed with postwork. I hope they get around to addressing this in one of the patches.
