soccer coach opened this issue on Nov 24, 2002 ยท 11 posts
soccer coach posted Sun, 24 November 2002 at 5:05 AM
CL: Lets quit worring about what kind of machine every one is running and start writing some porper code.
Yes, I have downloaded and installed, and reinstalled the latest and greatest beta fix.
PhilC posted Sun, 24 November 2002 at 5:13 AM
wgreenlee1 posted Sun, 24 November 2002 at 5:57 AM
LordNakagawa posted Sun, 24 November 2002 at 6:22 AM
As bad as P5 is I do not think this is bug but a result of the overly complex hair system. It looks like the hair is made of two peices when you clothify it the hair splits apart. Two solution will be to 1) set teh whole object at "decorated soft" or constrained 2) clothify only the sides and keep the seam area set at normal or at "decorated soft" or "constrained" this is the best option and teh most realistic I think. PS Like the 'do. Kinda like an inverse mohawk befitting an alien.
Valandar posted Sun, 24 November 2002 at 10:06 AM
It's because the vertices are split at the seams. Take the obj into UVMapper, weld the vertices, and bring it back in. This is not a coding issue. Period.
Remember, kids! Napalm is Nature's Toothpaste!
saxon posted Sun, 24 November 2002 at 10:26 AM
Hair isn't cloth. It's a neat work around and Valandar, thanks for the tip, but I find Poser hair works pretty well for me....
zechs posted Sun, 24 November 2002 at 2:30 PM
It's pretty annoying when people bitch about things that are hacks to begin with, not working perfectly the first time they try. 3d isn't easy. get used to it.
bloodsong posted Sun, 24 November 2002 at 4:02 PM
heyas; mine did that all the time too, until i got straightened out. this is how you do it: 1: import your cloth-hair prop. don't parent it to anything, or you'll be messed up. 2: clothify it as normal. make sure you create a constrained group at the roots, where you want it stuck on the scalp. 3: NOW parent the cloth-hair to the head. then the vertices will stick to it. remember: constrain first, parent after.
zechs posted Sun, 24 November 2002 at 8:52 PM
I'm guessing It would also be good for trying to do a more cartoony representation of hair like lets say a Dragon ball Z anime style. :)
soccer coach posted Mon, 25 November 2002 at 9:00 AM
Thanks for all your help and constructive suggestions.
I was working on this item at 4 AM and was not thinking at all.
Thanks zechs, your comment is inspiring. I've been hacking since Poser1.
zechs posted Mon, 25 November 2002 at 9:51 AM
Hax0r 0n :)
