madasatadpole opened this issue on Nov 26, 2002 ยท 10 posts
madasatadpole posted Tue, 26 November 2002 at 9:48 PM
it looks great in poser but when i import i just get a grey figure as vue is loading it in i get asked for a bitmap so i browse to poser look for it find it double click it vue then loads it but when i render its terrible i had a bit of luck with daz reindeers but even they arnt as good as i did them in poser ..can any one tell me what i,m doing wrong ....regards(davy)
Djeser posted Tue, 26 November 2002 at 11:42 PM
Are you importing the pz3 file? If you import it that way, it should be fine. I don't get any requests for loading the materials. If you have the latest update to Vue, you should be able to import the Poser 4 figures directly without having to save them as 3ds or other format.
wabe posted Wed, 27 November 2002 at 12:43 AM
Mac or PC? On the Mac it is important that all bitmaps are not organized in sub-folders. If that is the case, Vue does have big difficulties to find them! But as Dieser said, if you are importing pz3 files and if you are using the latest version 4.1 of Vue, it should be ok. Maybe its a good idea that you give us an example what you mean with "terrible" - compared to Poser. Walther
madasatadpole posted Wed, 27 November 2002 at 3:27 AM
what an idiot i feel thanks guys i've been importing as wavefronts and 3ds figures i took bad advice elsewhere thats solved it i,m a bit naive being new to importing and such stuff...its my own fault for not checking things out properly..many thanks (davy)
spratman posted Wed, 27 November 2002 at 8:55 AM
Speaking of Importing Poser into Vue. I've been looking at purchasing Vue4.1 specifically for what I've heard as its great relationship with Poser. I've also read in past about problem with the mac version. What's the current status?
wabe posted Wed, 27 November 2002 at 9:10 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=286325&Start=1&Sectionid=3&WhatsNew=Yes
the status Mac wise? It works. Look at this image from TheWingedOne, done on a Mac - and see. As mentioned above, the most important thing you have to keep in mind is, that Vue is a little sensitive regarding bitmaps. In the context where they are saved! But if you avoid that... But dont forget, we are talking about import filters. And each import filter does have weak points. For example Vue is not yet able to deal with Poser 5 files - because Poser 5 came out after Vue 4.1 was published. I think there is no other app out there (in this price range), which is able to deal with Poser so easily. WaltherOne day your ship comes in - but you're at the airport.
Djeser posted Thu, 28 November 2002 at 3:23 AM
I use Poser 4 with Vue 4.1 all the time. If I hadn't had Vue already, I would have purchased it for the ability to import Poser files alone, although I like it for a lot of other reasons. I am on PC, so can't speak to the Mac issues. You can import the props, everything, as long as you put it into a scene in Poser first and save it as a Poser file.
TheWingedOne posted Thu, 28 November 2002 at 7:21 AM
Attached Link: http://www.renderosity.com/gallery.ez?ByArtist=Yes&Artist=TheWingedOne
Spratman, just like Walther aka wabe already said. Always make shure that the textures of the objects you'd like to import are not in nested folders. Simply put them into the "Runtime/textures" folder and there you go. After recognizing this issue import with Vue 4.1 worked like a charm on my Mac. Thanks a lot wabe to rely on my last pic for reference purposes! :) Though I have to admit that I did quite some more work on the textures... If you use Poser 4 (not Propack) the bump maps are saved as BUM-files which Vue can't read correctly. So I resaved those as JPEG-files and applied them to the approprite texture. But I have to admit this is way much easier then within Bryce. Looks like Vue finally got me! :) Vue is really worth the money, spratman. Try the demo and you'll understand what I want to say. Philmadasatadpole posted Thu, 28 November 2002 at 1:07 PM
thanks everyone looks like i opened a can o worms there using the original poser file works fine ..i can do some serious work now.. they do go together well its a pity they arnt merged into one ..now that would be a powerful bit of software ,,thanks very much for all your replies to my question regards (davy)
vasaforever posted Mon, 23 December 2002 at 2:38 PM
now the question I have is how do you animate imported Poser scenes in Vue? I am totally stumped and I don't want to have to do it frame by frame.
