Subject: Poser Export Problem
TrueBQ opened this issue on Apr 13, 2000 ยท 4 posts
TrueBQ posted Thu, 13 April 2000 at 1:58 PM
Has anyone else who has installed the latest Poser Update Patch noticed that you can't select the check box to export (to 3ds, obj or dxf) a figures individual body parts? Does anyone have a fix to this?
JeffH posted Thu, 13 April 2000 at 4:35 PM
E-mail Larry about it at ghost Effects.
Swayne posted Thu, 13 April 2000 at 5:58 PM
I have a fix for you...but it ain't so purty.... I had that same problem(as did others) it has to do with *.arp files being duplicated...poser won't export/import with more than one copy. (in my case...windows had copied them to it's temp directory????) what I had to do was uninstall poser, then do a search for all .arp files on my hard drive and erase them. Then I reinstalled poser and it's patch and Viola'...pain in the butt. you might try searching the forum for an easier solution...hope someone has some better news...good luck
LoboUK posted Fri, 14 April 2000 at 5:07 AM
Hmmm, that's pretty much what I had to do - only in my case I'd got a 2nd copy of Poser4 on another drive !!! When I killed all of the arp files and re-installed - it worked Paul
