Forum: Poser Technical
Subject: poser4 export to bryce
Lemmelin opened this issue on Dec 08, 2002 ยท 3 posts
Lemmelin posted Sun, 08 December 2002 at 12:25 PM
Hi, i am new with using poser, but very good using bryce 5. My question is, What is the best file-format to export the poser-figures in into Bryce? Is there any tricks whith doing it, or just export? Lemmelin (swe)
daveH posted Mon, 09 December 2002 at 6:11 AM
if you use poser's obj exporter bryce can read both the geometry (.obj) and material (.mtl) files that get exported, as long as they're both in the same directory. and make sure you weld the figure, so you don't get seams in the model.
Bladesmith posted Tue, 10 December 2002 at 2:13 AM
you might want to pick up a program called grouper (new version was in freestuff just a day or 2 ago), and another called metalfixer....both of these programs can fix problem obj's that bryce rejects. Metalfixer can keep the textures intact so you don't have to go searching for them on import, but I usually export untextured, then load the textures in bryce.
